Author Topic: black textures  (Read 6128 times)
barl99
black textures
« on: July 12, 2010, 01:07:53 am »
whenever i add a texture to a brick it is just black how can i change this? now =    ??? if you answer =  ;D
odp04y
Re: black textures
« Reply #1 on: July 12, 2010, 03:56:14 am »
Change the GUI settings to display textures.
Otherwise render an image and the texture should be there.
TheRetroZombie
  • I do crap animations.
    • Youtube Channel
Re: black textures
« Reply #2 on: July 17, 2010, 02:50:15 pm »
Use the UV tool which in the "Object Editor". The tool that has "UV" on it. You would have to rotate the texture to make it match. You will see it once you move. Hope this helps. If it doesn't Ill give you more help.
X
zack247
Re: black textures
« Reply #3 on: July 21, 2010, 02:30:22 pm »
sometimes the texture appears darker than usual. at least it does for me. i generally just try different specularity and emissive values to get it displaying right
