Author Topic: How to use textures  (Read 6794 times)
bogB
How to use textures
« on: January 10, 2010, 04:59:21 pm »
I tryed to do almost everything and i still dont understand why i get only one color for that object instead of texture i added? can someone tellme what im dooing wrong?
I know that this works on sphere i cant understand why its not working on this object.
« Last Edit: January 10, 2010, 05:33:59 pm by bogB »
siragin
    • Shatalu Productions
Re: How to use textures
« Reply #1 on: January 10, 2010, 06:06:21 pm »
I don't know why that happens, but to fix it all you have to do is hit the uv button in object mode. It will ask you to enable texture genorator and click ok. After the yellow uv box pops up double click on the box. and his ok in the menu box. Your texture should show up.
Ok I know what the problem is. the uv's in your mesh is screwed up and your texture is distorted. Just do as I just mentioned and it should be good.
bogB
« Reply #2 on: January 10, 2010, 06:24:44 pm »
siragin, ty ty ty :)
