Author Topic: Cutting effects (Close please, question answered)  (Read 6775 times)
lloonnee2
« on: December 06, 2009, 02:11:30 am »
Yes, well I'm working on a lightsaber fight in Anim8or, and I was wondering if it was possible to add morphs to a bone. Most of the script in the fight has a dismemberment one way or another, one limb gets chopped off or something, but the only way I've done a cutting effect in my previous animations was to work with solid objects, add in a morph that shows the cut made, and edit the values of the morph in the scene.
I'm using the traditional skeleton stickman for thos project, but it would look unrealistic if the saber went through a stickman's arm and nothing happened. I think the only way to add the effet of a cut on a stickman would be to add a cut morph to an object, then import that ibject to a bone on the stickman, and edit from the scene. Would this be possible?
« Last Edit: December 06, 2009, 07:03:48 am by lloonnee2 »
Re: Cutting effects
« Reply #1 on: December 06, 2009, 06:18:48 am »
Morphs can certainly be applied to Objects that are also used in a Figure, and the morph targets can be keyframed in Scene mode.
johnar
    • youtube vids
Re: Cutting effects
« Reply #2 on: December 06, 2009, 06:30:26 am »
 If stickman already has a body, and that body is 1 object, then you would make the whole stickman object your morph object, and add the 'cuttoff' morph target(s) to that.
 If there are seperate objects attached to rig, ie: legs, arms, torso, head etc, then you would treat each object seperately.  :)
« Last Edit: December 06, 2009, 06:35:54 am by johnar »
lloonnee2
Re: Cutting effects
« Reply #3 on: December 06, 2009, 07:02:44 am »
Thanks for the replies, I'll add cutting morphs to the stickman skeletons.
