Author Topic: Need help on a busted file  (Read 8354 times)
Dreadkb
« on: October 24, 2009, 07:17:01 pm »
 Got a project I'm doing for a friend. Unfortunately, it got corrupted. I've tried finding the error, but I don't know enough about the language used by Anim8or. Could anyone please check this file for anything screwy? Her final project is due Friday, so time is of the essence.
RudySchneider
Re: Need help on a busted file
« Reply #1 on: October 24, 2009, 07:47:08 pm »
Corrupted how?  As in some of the objects are messed up, or the scene keyframes are screwy, or that you simply can't open it?  I was able to open it OK, and except for not having the texture files, it looks OK to me.
G
« Reply #2 on: October 24, 2009, 07:51:44 pm »
As RudySchneider said, works fine.
Dreadkb
« Reply #3 on: October 24, 2009, 09:19:01 pm »
Well, then I guess that this is one for the weird files. When I try to open it, Anim8or just says "Anim8or has encountered a problem and needs to close. We are sorry for the inconvenience." It stops trying to load and can only be closed. I'll try moving the textures that I'm using one at a time until I find the problem. Thanks for the speedy response.
TheBlackHole
« Reply #4 on: October 25, 2009, 03:44:03 pm »
You mean it crashes.
