Author Topic: Is there a way to convert other Mesh files into anim8or files?  (Read 12300 times)
Roy_Raimi
« on: October 21, 2009, 03:49:29 pm »
Like I have this mesh file I want to open in anim8or so I can edit it and stuff, but it would'nt allow it. So I tried renaming it from "test.mesh" to "test.an8" but it says everytime I try to open it
says "Error reading file" Is there any way to convert other meshes, so I can open and edit it in anim8or?
lynn22
    • 3D Animation
Re: Is there a way to convert other Mesh files into anim8or files?
« Reply #1 on: October 21, 2009, 04:32:10 pm »
Just renaming a file won't work.
Anim8or can import :
3DS Max (.3ds), Lightwave (.lwo) and Wavefront (.obj) files
You will need to convert your mesh into any of these formats before you can import it ;)
Pincho
« Reply #2 on: October 21, 2009, 05:42:27 pm »
What is .mesh?.. never heard of it.
rellik420
    • youtube channel
« Reply #3 on: October 22, 2009, 03:25:06 am »
i think .mesh might b autocad or something.
but if you go to the search on the forums. tyr searching conversion or somethng because ive seen posts talking about programs which converts a bunch of extensions like .x for instance.
im sure you can find something on the net tha6 will convert a .mesh into a .obj or .3ds. even if you have to inport your.mesh then export it into a .obj
hope this helped
h
Roy_Raimi
« Reply #4 on: November 04, 2009, 07:37:39 pm »
Ok so how could I convert anything to a .3ds .lwo and .obj files?
Is there a software I can use for that?
rellik420
    • youtube channel
« Reply #5 on: November 04, 2009, 08:05:26 pm »
im sure there are a few of them out on the net. i would try .mesh to .obj export or convert. i dont think it would take that long to find one.
personally i would go with .obj (i may be wrong here) i think when you export a model in 3ds it triangulates it. but in your case i would go with what ever works, you can always delete some lines in anim8or.
good luck gettin what you need.
you do seem a little confused though. this is how export works.
say you create a model. you exprt the model and it turns into a file. depends on what filetype you want it... you export your model in what ever format you want.
importing models is pretty much the oposite. you need a file to import into your program. so say some1 gave you a model in .obj or .3ds or what ever. you would go to your program and import that file (model) into your program.
thats pretty much all there is to it.
h
lppena
  • Anim8or, does a body good.
« Reply #6 on: February 13, 2013, 09:36:40 am »
Just FYI but 3D Exploration is an excellent free file converter. Another free option is Biturn. Also, I believe Blender may be able to import the .MESH format, but it may only be able to export as I recall. As I recall someone also created an Orbiter export script for Anim8or.
