Author Topic: My first Animation-sadly unsatisfied  (Read 8504 times)
Lama
    • musiXtools stompboxes
« on: April 04, 2009, 06:33:40 pm »
It´s a trial to an Intro for my projects in the future.
You can see it on YouTube youtube.com/watch?v=mixY1Mct5eE[/youtube]]http://www.
Most unhappy make me the water (do you see that it shall be water?)
I have try to use a tutorial, but something go wrong and so I try to make water with my own art, but without luck  :-\
Have someone an idea, what I can make better?
thanks
Geli
lynn22
    • 3D Animation
Re: My first Animation-sadly unsatisfied
« Reply #1 on: April 05, 2009, 05:51:06 am »
I think that your water would look better if you used a different picture for your sky. There is not enough difference between the two which makes you lose the effect you made with the water.
I would also suggest to use a higher resolution worldmap image, it does not look too good when the globe comes close by ;)
« Reply #2 on: April 05, 2009, 06:23:37 am »
I looks pretty good. I like the particle effect on the text.
The water could indeed use some work: try some of the ART reflections.
Also the world texture could be higher res. Try these maps: http://planetpixelemporium.com/earth.html
mak
« Reply #3 on: April 06, 2009, 01:52:42 pm »
the water looks fine,  i mean no its not pixar quality, but you dont have a giant render farm at your disposal do you.(do you?)
realisim is for reality
Lama
« Reply #4 on: April 06, 2009, 06:00:06 pm »
Many thanks,
next I´ll try it with Art reflections, but first I will learn more and better understand about this method.
Now I have see, that the flying earth is an "old hat", so I think that is better to change the Idea, we´ll see.
@mak, I do not really understand "but you dont have a giant render farm at your disposal do you.", because my knowledge of english is only rudimental  >:(
Tanzim
« Reply #5 on: April 07, 2009, 05:20:06 am »
A render farm is basically many computers working together to create an image, the main advantage is that they can create an image faster than a single computer could by itself.
