Author Topic: Object rigging  (Read 14480 times)
Airedale11
Object rigging
« on: March 18, 2009, 01:16:17 pm »
I tried to rig (make into a figure) a single object but it comes out looking like gum in the sequence editor... I did read the manual (twice) but it didn't help.
EDIT: Heres the object I'm trying to rig...
« Last Edit: March 18, 2009, 01:21:24 pm by Airedale11 »
Re: Object rigging
« Reply #1 on: March 18, 2009, 01:55:58 pm »
If you add the the file which you rigged we might help you and see what you did wrong. Now you have only added the character model, we can't really help you this way. When you follow the manual exactly there shouldn't be a problem.
Maybe try this tutorial: A simple walk. Which explains basic rigging.
Airedale11
Re: Object rigging
« Reply #2 on: March 18, 2009, 01:57:17 pm »
I did try the "A simple walk tutorial" but that's for a figure with multiple objects.
Re: Object rigging
« Reply #3 on: March 18, 2009, 01:59:50 pm »
The basics stay the same. Only now you have to apply the character to a origin bone and use skinning to attach the object to the right bones.
Airedale11
Re: Object rigging
« Reply #4 on: March 18, 2009, 02:05:52 pm »
OK so look at this one and tell me what I'm doing wrong.
Re: Object rigging
« Reply #5 on: March 18, 2009, 02:11:54 pm »
Well you didn't do anything wrong, since you didn't do anything. You first have to attach the bones to the object using skinning (link above). Now you have only make two bones.
Airedale11
Re: Object rigging
« Reply #6 on: March 19, 2009, 12:56:16 am »
I did attach it to the bone
Re: Object rigging
« Reply #7 on: March 19, 2009, 01:34:50 am »
Now, using the skinning tool, you need to change the envelopes so that they enclose the entire area of the mesh that you want the bone to influence.  Currently they are not surrounding any vertices, and therefore are not influencing any vertices.
lynn22
    • 3D Animation
Re: Object rigging
« Reply #8 on: March 19, 2009, 05:15:52 am »
You can find step by step guides for bones and skinning here
Airedale11
Re: Object rigging
« Reply #9 on: March 19, 2009, 12:20:57 pm »
This is really frustrating! I wanted to use my character in a scene and I corrected everything in the figure editor and I made a walk sequence too, but then... THE PROGRAM HAD AN ERROR AND I DIDNT EVEN GET TO SAVE IT!!!
lynn22
    • 3D Animation
Re: Object rigging
« Reply #10 on: March 19, 2009, 01:01:53 pm »
It is frustrating. Just make sure that under File > Configure you have Autosave checked and have specified a directory where to autosave to, then at least you won't lose everything.
