Pages: [1] 2
Author Topic: edgelooping  (Read 21081 times)
captaindrewi
  • errm...errr?
edgelooping
« on: February 17, 2009, 10:11:09 am »
i once followed an edge looping tutorial/video for anim8or.
and at the time built half a face.
but i cant find it and i have forgotten how to do it.
very grateful for any links.  ???
Maxfield
Re: edgelooping
« Reply #1 on: February 17, 2009, 11:00:45 am »
You might try
http://www.mp3d.info/Anim8ortutorials/page1.html
and scroll to the bottom.
Or have a look at the links in the tutorials section.
captaindrewi
  • errm...errr?
Re: edgelooping
« Reply #2 on: February 17, 2009, 12:17:23 pm »
thanks for replying but the links are dead
Dreadkb
Re: edgelooping
« Reply #3 on: February 17, 2009, 02:11:52 pm »
I just posted this in another thread yesterday.
http://www.subdivisionmodeling.com/forums/showthread.php?t=8911
captaindrewi
  • errm...errr?
Re: edgelooping
« Reply #4 on: February 17, 2009, 02:56:26 pm »
yeah i  have downloaded that info for safe keeping, but i need some instruction on how to begin the process
i seem to remember starting at the mouth and looped sections being generated some how.
Re: edgelooping
« Reply #5 on: February 17, 2009, 08:52:13 pm »
There's a great primer explaining a lot about subdivision modeling.
http://www.subdivisionmodeling.com/page1.htm
There are many different ways to model different objects.  You can find a lot of tutorials using different programs that will be just as useful for you such as the Joan of Arc tutorial.
captaindrewi
  • errm...errr?
Re: edgelooping
« Reply #6 on: February 17, 2009, 11:38:42 pm »
thanks for those links  they are very helpful.
but this is close to what i rembember, the parts being generated semi automatically.
« Last Edit: February 18, 2009, 12:23:37 am by captaindrewi »
rellik420
    • youtube channel
Re: edgelooping
« Reply #7 on: February 18, 2009, 02:03:28 am »
it looks like ur having the same problem i am having with the lips. its close but no cigar. i guess it depends on how u make the rest of ur face but keep workin at it. ull get it eventually.
(it kinda loks like lips on a muppet)
h
captaindrewi
  • errm...errr?
Re: edgelooping
« Reply #8 on: February 18, 2009, 05:44:55 am »
sadly i'm not that far yet, the above mage is made my someone else.
xalener
Re: edgelooping
« Reply #9 on: February 18, 2009, 05:12:53 pm »
It's MP3D's tutorial. It helped make me the modeler I am now.
I can't find the tut either though. :(
Oh! Rellik, the lips were sopposed to look like that. You'll understand it when you see the full face that was made in the tut.
Re: edgelooping
« Reply #10 on: February 18, 2009, 10:22:44 pm »
captaindrewi: that tutorial is not showing every step in the program.  All it's demonstrating is how the lips are made up of loops.  There is hardly any modeling that is done automatically like that.  You can use edge extruding, but you still have to reposition vertices to where you want them.
captaindrewi
  • errm...errr?
Re: edgelooping
« Reply #11 on: February 19, 2009, 07:20:21 am »
thanks for replying,i bow to your knowledge hiho.
perhaps edge extruding was used in this fabled demo/tutorial
i once followed.i
so infuriating that i didn't save the information at the time.
i am saving as much anim8or technical tute info as i can nowadays
just in case it fades away.
xalener
Re: edgelooping
« Reply #12 on: February 19, 2009, 05:38:09 pm »
It was.  A lot.
captaindrewi
  • errm...errr?
Re: edgelooping
« Reply #13 on: February 20, 2009, 07:33:28 am »
trying to construct face/head using this method......but cant make the lines solid. ???
so can't progress to joining it all to make faces. :-\
« Last Edit: February 20, 2009, 07:37:54 am by captaindrewi »
$imon
Re: edgelooping
« Reply #14 on: February 20, 2009, 08:20:30 am »
The lines you have drawn so far are 'splines'. In anim8or splines are no more than helper lines.
To make a model you will want to make edges instead in the point edit mode (have a look in the manual for all that.)
Once you have made the lines as edges in the edit mode, you can create edges in between those and fill them to make the shape of the face.
Good luck!
Pages: [1] 2
