Author Topic: Paths - Help Please  (Read 8775 times)
Richardm
Paths - Help Please
« on: February 13, 2009, 06:43:37 am »
I am struggling with getting a path into a scene. I have created a closed spline and transferred it into the scene (as an object) but cannot get the scene to recognise it as a path - cannot be highlighted or edited via the respective buttons. I can select it and manipulate it as any other object but cannot get it to turn into a path.
Have tried this numerous times in the 'production' and 'preview' versions.
Would someone please point out the obvious for me please
Thanks
Richard
  • Flying Platypus
Re: Paths - Help Please
« Reply #1 on: February 14, 2009, 06:11:00 am »
A path in the object mode is something very different than a path in the scene mode. It may be quite confusing, I know...
A path (spline) in the object mode is used as a modeling tool - you can extrude it, lathe it or fill it, but the path itself is "useless" and it's not visible in rendered images.
A path in the scene mode is created whenever you animate the position of an object. The path represents the object's trajectory and it can be edited using the graph editor or the "path" tool.
I hope it helped...
Richardm
« Reply #2 on: February 14, 2009, 08:34:57 am »
It did (help), must have misread or misunderstood something - grateful thanks. :)
« Reply #3 on: February 14, 2009, 01:18:27 pm »
RichardM: This facility that is in the BUILD part og the scene editor is not implemented , however I would suggest you take a look at NickE`s thread in the scripts section as there is a script to make a path for your object in scene mode
It would be nice to have this implemented in Anim8or
http://www.anim8or.com/smf/index.php?topic=959.msg6992#msg6992
Think thats the link ....
Anyway I think really that its about time it was implemented in Anim8or
« Last Edit: February 14, 2009, 01:25:33 pm by kreator »
