Author Topic: Set a specific view to a view pane  (Read 7966 times)
Pirmin
« on: October 31, 2008, 02:58:21 am »
Is it possible to set a specific view to a view pane?
When I choose 2 Views, the Front is displayed on the left side and the Top Views displayed on the right side.
Sometimes I would like have different views displayed, for instance the Top view on the left side and the Camera View on the right side.
lynn22
    • 3D Animation
Re: Set a specific view to a view pane
« Reply #1 on: October 31, 2008, 04:40:36 am »
If you click on the name (top left of a view pane) you can change it to another view.
Pirmin
« Reply #2 on: November 01, 2008, 03:40:08 am »
Thank you!
This works good with the 4 panes view (Scene Mode).
When I try to do it with 2 Views, it always changes to a single view (perhaps my operation error?).
However I found a workaround to set 2 Views as desired, following your advice.
In the 4 panes view I set my desired two views to the upper two panes and the same two views to the lower panes.
After that, when I change to 2 Views, my desired two views are displayed.
lynn22
    • 3D Animation
« Reply #3 on: November 01, 2008, 06:48:00 am »
Glad you found a solution which works for you :)
