Author Topic: Making a tree  (Read 14242 times)
aGMuser
Making a tree
« on: October 26, 2008, 07:27:36 am »
Okay, it was long time since from my last post here.I'm making a 3D RPG game and I'm doing very well.Now I want to make some trees, but I stuck at the branches.What I want to ask is is there any good method, tutorial or some way for quiclky making all branches at once, or I should make them separate?I don't need hyper-extra-ultra-maximum quality, but it needs to look realistic.
headwax
    • Headwax's Website
Re: Making a tree
« Reply #1 on: October 26, 2008, 08:22:12 am »
Look into transmaps. Otherwise your mesh count will be High.
aGMuser
Re: Making a tree
« Reply #2 on: October 26, 2008, 08:25:28 am »
What do you mean by transmaps?
Francesco
Re: Making a tree
« Reply #3 on: October 26, 2008, 08:26:22 am »
Hi aGMuser, take a look here:
http://www.kurtz-fernhout.com/summary_plantstudio.html
...it's a bit old but it's free and it's fully customizable.
Although it isn't intended to make trees, you can generate a tree-like plant, export it in a 3d format that Anim8or can read and then work on it.
aGMuser
Re: Making a tree
« Reply #4 on: October 26, 2008, 08:28:15 am »
Thanks, I'l try it.
falloffalot
Re: Making a tree
« Reply #5 on: October 26, 2008, 09:22:29 am »
A trans map is a way of adding a fake object without the model. As you are game making I'm not sure to the effect of collisions with your player_object. You could model a simple tube with a transmap applied then give just the base a collision property.
aGMuser
Re: Making a tree
« Reply #6 on: October 26, 2008, 09:53:43 am »
I can't understand you completly.Do you mean exporting several objects(branches) and then putting them into one?And don't worry about the collision - it is fully 2D and the models have nothing related to it.
Sluggs
  • Anim8or user since May 2004
    • Satans-Comrade
Re: Making a tree
« Reply #7 on: October 28, 2008, 10:59:50 pm »
You want free tree making programs?
Check these out...
Easy Tree Generator - http://ttlg.com/forums/showthread.php?t=115701
Simple Tree Creator - http://ttlg.com/forums/showthread.php?t=115595
tree[d] - http://www.frecle.net/forum/viewtopic.php?p=3810#3810
Have fun with those!  :D
aGMuser
Re: Making a tree
« Reply #8 on: October 29, 2008, 03:54:20 am »
Thanks, this is what I need.
