Author Topic: subdividing faces PLS HELP!!!  (Read 10826 times)
Jared D
« on: October 02, 2008, 01:11:41 pm »
ok, I made the hand in mesh, but when I go to subdidive faces, it says "you must select a single mesh to subdivide."
and hen I select thewhole thing it says " you have selected a group. you must select a single mesh to subdivide."
how do I fix that and subdivide faces?
Re: subdividing faces PLS HELP!!!
« Reply #1 on: October 02, 2008, 01:47:43 pm »
un-group the object(s).  Either go Build>Ungroup or press 'u' a few times.  It seems you either have a group of objects, or you accidentally grouped your one object with itself (which is possible, you may have accidentally pressed 'g' with the object selected.)
Oh, and don't "subdivide faces..." use "Build>convert to subdivided" instead.
Jared D
« Reply #2 on: October 02, 2008, 02:22:42 pm »
thanx, it worked.
Jared D
« Reply #3 on: October 02, 2008, 05:11:08 pm »
ok, there is another computer in my household, and it is running windows vist home premium. I cannot find the "run winxp compatable" button. I'll bring this up in the chat box real quick.
« Reply #4 on: October 02, 2008, 05:43:53 pm »
right click on the anim8or.exe go properties>compatablilty and then 'run this program in compatablity mode' --> select windows xp.
Jared D
« Reply #5 on: October 02, 2008, 07:03:00 pm »
Ithanx, i'll try thn a minuet, I have a lot of Qstions, so I think i'll make this another newB topic.
Q.1 I can't get the Pentagon twork correctly  the egg plant, so what v do I make that in?
B3dman
« Reply #6 on: October 03, 2008, 05:00:40 pm »
are you having trouble with the extrusion? lots of people have trouble with that.
Galatians 5:6
