Author Topic: Makmat 160mm (Mobile Artillery)  (Read 11811 times)
Aqo
« on: September 25, 2008, 08:33:09 am »
The Makmat 160mm is a mortar mounted on a Sherman chassis adopted in 1968 and used to this day. I decided to model it using Anim8or.
Here is the main reference image I'm using:
http://img150.imageshack.us/img150/524/makmat160beythatotchan2bi8.jpg
I was originally aiming to keep the whole thing under 10k faces but while working on it I decided to go for a more detailed model. Here is what I've got so far, which amounts to about 29k polies:
Here's a more close-up look at the front wheel comparison:
I'd love to hear any opinions and suggestions.
Raytraced:
« Last Edit: September 25, 2008, 09:43:31 am by Aqo »
CowTail
Re: Makmat 160mm (Mobile Artillery)
« Reply #1 on: September 25, 2008, 10:24:39 am »
Looks pretty accurate so far, I like you progress :)
Some of the smaller details aren't dead-on (like the rivet heads between the treads, the original has two circular indentions and a long thin bump on the top), but that's getting anal ;)
The texturing is alright, can't complain too much there except that the only real way to make it look better would be to customize it a bit and add dirt and wear and tear, like in the original. You should also add another sand-colored light source facing from the ground to give it some backlight and make the render a little more realistic. Generally you should have two or more lights in a lighting setup if you want to go for more than a basic render.
Keep it up!
« Reply #2 on: September 25, 2008, 11:16:05 am »
Wow, great attention to detail. I don't really like the texture you used, but great model. At first I thought it where a reference images you posted, but the turned out to be the actual model.  ;D
Can't wait to see the model finished!
KiwiNM8OR
« Reply #3 on: September 26, 2008, 04:17:58 am »
And moving too All the pieces and dimensions seem to fit and looks as if it would work.
Meanwhile...
Happy Anim8ing
http://www.youtube.com/user/KiwiNM8OR
