Author Topic: Anim8or/Panda3D problem  (Read 16105 times)
The Great Noob
  • I run Vista. I don't know how i lived without it.
    • Day7 productions
« on: September 24, 2008, 04:04:12 pm »
I've been experimenting with Anim8or and Panda3D and I've got a problem.
Here are the exact steps I take:
1. make the model in anim8or
2. export to Wavefront(.obj) format
3. import into *blegh* blender (I'm NOT capitalizing the b!)
4. export to DirectX(.x) format
5. type the necessary code to load the model and make it visible:
Code: [Select]
import direct.directbase.DirectStart
head = loader.loadModel("models/head.x")
head.reparentTo(render)
run()
the model shows but the materials don't ???.
Any suggestions?
Maya is a threat to Anim8or:
All personnel to the bridge! We attack at noon!
Re: Anim8or/Panda3D problem
« Reply #1 on: September 24, 2008, 04:43:41 pm »
apparently, when you save a .obj, the materials aren't saved in the .obj file itself, but in an accompanying .mtl file.  anim8or 0.95 doesn't support .mtl files, so if you're still using 0.95, you might want to consider upgrading, as anim8or 0.97 does support .mtl at least for import, i'm not sure if it also exports that format but it could be worth your while to have a look at it.
of course, if you're already using 0.97 then i'm stumped...
mcheccyb
« Reply #2 on: September 24, 2008, 04:46:59 pm »
whats wrong with blender?
The Great Noob
    • Day7 productions
« Reply #3 on: September 24, 2008, 05:00:07 pm »
I can't for the life of me figure out how to use it.
as far as i know i'm on 0.97.
I think I found the problem. .x format does not support materials. Let me do a quick test, I'll update soon
EDIT: Ah-ha! Panda3D shows TEXTURES by default and when going through blender the materials become shaders! I just need to find out how to change this.
EDIT 2 ATTACK OF THE EDITS!: OK so I am using 0.95 but i can't find the link to download 0.97. Where is it?
EDIT 3 REVENGE OF THE EDITS: nevermind.
« Last Edit: September 24, 2008, 05:15:47 pm by The Great Noob »
Darkjesture
« Reply #4 on: September 24, 2008, 05:26:58 pm »
I thought it only saved .mtl when you made materials(it does for me)
almost cool
  • The Truffle Shuffle
    • www.deadboltdevelopment.com
« Reply #5 on: September 27, 2008, 01:53:51 pm »
U doin this for our project?if so virtual hug,second,if u havent,try posting on the panda 4ems.
The Great Noob
    • Day7 productions
« Reply #6 on: October 03, 2008, 11:32:16 pm »
Yes I'm trying to learn Panda3D so we can at least throw together betas.
