Author Topic: Hole in Cube  (Read 16959 times)
Ralf1324
    • Fisher Lighting
Hole in Cube
« on: January 14, 2008, 03:45:28 am »
I have a cube in which I need a circle cut through the middle. Any ideas?
-=Ralf124=-
Kilminster
Re: Hole in Cube
« Reply #1 on: January 14, 2008, 07:39:46 am »
Somebody posted a way to do it with transparency maps (although that doesn't really do a hole, just something that looks like one).
The present version of terranim8or can do booleans and for clean shapes like a cube and a cylindrical hole it will probably give good results.
For not so simple shapes there is still the "manual method. Built the two shapes you need (here a cylinder and a cube; you have to build meshes out of primitives first), join sloids and then with the slide tool move points to create the merging line. remove unwanted faces, recreate the ones yu need and then you have it.
Louder is better!
headwax
    • Headwax's Website
Re: Hole in Cube
« Reply #2 on: January 14, 2008, 08:36:58 pm »
Hello  for a cilinder through a cube?
Make cube. Remove faces where the  cyl will go through. Group the cube with itself and this will stop you moving points.
accidently.
Mek cylinder the correct lenght and  width.
Remove end faces of cyl.
Select all edges at one end of the cyl. Extrude edges sideways at 90 dgegrres to cyl. In top view make the extruded points a  square shape the same size as the cube face. Do same with bottom of cyl.
Move cyl to  correct position. Make  cuts in the edges of the removed faces on the cube (after ungrouping cube). Aim is to line up the vertices on the cyl's new square face with your new cuts on the cube.
Join  cube and cyl. Select all verticies and marge points.
RudySchneider
Re: Hole in Cube
« Reply #3 on: January 14, 2008, 09:12:08 pm »
Here are a couple threads from the old Anim8or.com forums that may be helpful:
http://www.anim8or.com/ubb/Forum1/HTML/010103.html
http://www.anim8or.com/ubb/Forum1/HTML/016118.html
G
Re: Hole in Cube
« Reply #4 on: January 15, 2008, 12:53:51 am »
How about draw a square, place a N-gon with 32 sides in the centre of it, select them both and select Join Splines, then extrude the spline in the Z dimension.  Voila!
RudySchneider
Re: Hole in Cube
« Reply #5 on: January 15, 2008, 10:22:07 am »
And what are you smokin'?  Show me!
G
Jene
Re: Hole in Cube
« Reply #6 on: January 15, 2008, 05:03:18 pm »
lol rudy :)
the end, no pain and fuss, i like this method a lot thank you ENSONIQ5 ^^ usually i just make a cylinder then go through the painful process of connecting the dots and filling holes ><
RudySchneider
Re: Hole in Cube
« Reply #7 on: January 15, 2008, 05:32:16 pm »
Cool!  Obviously, I didn't think this would work.  Live and learn...
G
Re: Hole in Cube
« Reply #8 on: January 15, 2008, 05:33:13 pm »
Thanks for the pics Jene, that is exactly what I had in mind.
headwax
    • Headwax's Website
Re: Hole in Cube
« Reply #9 on: January 15, 2008, 06:52:01 pm »
ahh the  sadly neglected spline :)
