Author Topic: Odeon Cinema Screen (WIP)  (Read 21418 times)
3D Joe Wiltshire
  • Winter's Coming :O
« on: August 21, 2008, 10:49:03 pm »
Well, i've never really finished everything, but i plan to this time, i've just decided to try modelling an Odeon Cinema screen (not just the screen, the whole room) since i'm pretty sure i can do it, and it should be pretty fun to do, attached is all i have so far.
C+C is welcome
headwax
    • Headwax's Website
Re: Odeon Cinema Screen (WIP)
« Reply #1 on: August 21, 2008, 11:49:08 pm »
Great start. Bevelling the edges on the seat would help to make it look more real. Also subdividing the top part of the seat to smooth it.
http://tw.
&eurl=http://animanon.com/Forum/index.php?topic=349.0
check out this vid by ensoniqu from animanon
3D Joe Wiltshire
« Reply #2 on: August 22, 2008, 11:28:04 am »
Yeah, i saw that before, really amazing, Luckily i'm only making one screen, not the whole cinema  (phew)
Thanks for the help.
« Reply #3 on: August 23, 2008, 09:55:46 am »
A tip from one who still bears the scars of building a cinema:  Keep your chairs as low poly as you can get away with.  Once the chair is duplicated hundreds of times the poly count can get very big very quickly.  As headwax says, bevelling the edges of the seats would improve their appearance considerably, and smoothing the edges should give them a softer appearance.  It might be worth modelling just one chair and bringing it into your scene many times, as this would allow you to easily adjust the complexity of the chair later to control the poly count and render times.
It looks like you are off to a great start, and I look forward to seeing how this unfolds.
3D Joe Wiltshire
« Reply #4 on: August 23, 2008, 12:17:06 pm »
Same here, i've never actually had the commitment to finish anything before... we shall see...  I have already slightly become bored with it... but i will attempt to prevail.
xalener
« Reply #5 on: August 25, 2008, 03:12:00 pm »
If it isn't an animation, ot the camera stays in the same relative spot, you could have hight detail chairs in the foreground and lower detail chairs in the background.
You could even have chairs way in the back that are just flat planes with transmaps on them.
TheCodedOne
    • Hierarchy Games and Graphics
« Reply #6 on: August 25, 2008, 04:25:17 pm »
Yeah billbording textures away from the camera is a pretty good Idea if your trying to keep the polycount low. It can result in a really good render if one does it right.
http://hierarchy2gds.webs.com/index.htm
"Don't argue with an idiot they will drag you down to their level and beat you with experience."
3D Joe Wiltshire
« Reply #7 on: August 25, 2008, 04:28:19 pm »
well i think i'm just gonna work on it when i get bored, and haven't really done anything on it since,  poly count doesn't really matter, i'm just making it for the sake of making it, to tell the truth.
