Author Topic: TOOL: Papaga8or - Automatize your morphs animations  (Read 33790 times)
« on: December 12, 2008, 04:23:09 pm »
Hi Guys,
i make a Little tool Software called of "PAPAGA8OR"
for be used with .an8 files.
This tool is for to maker AUTOMATE SENTENCE/SEQUENCE OF MORPHS
AND PHONEMES, use to SPEED ANIMATIONS WITH MORPHS
I made using Adobe Flash.
SEE BELOW:
- PAPAGA8OR and SAMPLES FILES be attacheds below zipeds for download
PLEASE TRY AND POST YOUR COMMENTS/SUGESTIONS BE WELLCOME.
Thanks so much All  ;)
Sorry my english..
neirao-brazil
« Last Edit: January 08, 2010, 09:19:21 am by neirao »
Re: Papaga8or tool - Automatize your morphs animations
« Reply #1 on: December 12, 2008, 04:46:56 pm »
follow below this tutor in PDF.
« Last Edit: December 13, 2008, 03:14:43 am by neirao »
texel
« Reply #2 on: December 12, 2008, 06:03:37 pm »
It's a good idea. I will test it.
Jaw Jaw
« Reply #3 on: December 12, 2008, 08:50:53 pm »
Impressive.
I uncovered no errors.
A very handy tool.
Good job!
Francesco
« Reply #4 on: December 13, 2008, 06:29:39 am »
Well done Neirao! That's really a useful tool for all Anim8ors.
I just downloaded it and I'll use it for sure, then I'll be glad to give my suggestion for improving it - if I'll have any, but from the screenshots seems like you have already done a great work.
« Reply #5 on: December 13, 2008, 11:31:05 am »
Brilliant work Neirao, your program works perfectly (tested with the sample files).
It sure will cut down animating time by not having to enter individual key values.
Well done :)
« Reply #6 on: December 14, 2008, 11:09:53 am »
Thanks for all comments guys, ;)
im very happy  :D
NOTE: i go make correction in "mode of sequence",
in current mode, this dont work with sequence over of 10 morphs..
if type "10" this see like "1", but i be make this correction..ok
CORRECTION: I said then "ADD YOU OBJECT WITHOUT NO MORPH KEYS ACTIVEDS", but you can yes add and WITH MORPHS KEYS ACTIVEDS,
you can MIXER several codes, paste and paste, after codes and codes OK.
aways after this line:
objectelement { "eobject01" "YOUR OBJECT"
    loc { (0 0 0) }
EXAMPLE: you make your character speak a setence..after you can creat a morph "morph01" and make a animation your character "blink", after you can type in Papaga8or "1       1         1       1        1", and paste the code in notepad, you caracter be SPEAK AND BLINK..OK
After i make a new tutor about.. ;)
Sorry my english..
Neirão
« Last Edit: December 15, 2008, 10:30:40 am by neirao »
Anton
« Reply #7 on: December 22, 2008, 12:53:27 pm »
Hi, I am new and would just like to know if someone has a tutorial on Animating a mouth with anim8ors morph targets?
« Reply #8 on: December 22, 2008, 02:23:43 pm »
Well, all you need to know is explained above ^. Make a head with a mouth. Set a new morph target and move the points in there new position.
More about morph targets here: http://anim8or.com/manual/3_object_editor.html#morph_targets
mookiestarhh
« Reply #9 on: May 15, 2009, 10:40:20 am »
hey, i was just wondering how i can try this program out?
« Reply #10 on: May 15, 2009, 12:08:11 pm »
mookiestarhh, :)
for try make download PAPAGA8OR and SAMPLES FILES.
http://www.anim8or.com/smf/index.php?action=dlattach;topic=1692.0;attach=2878
ok! ;)
mookiestarhh
« Reply #11 on: May 15, 2009, 11:01:22 pm »
YAY!! thank you heaps for that!!! I'll it out now!
le_pou
« Reply #12 on: January 06, 2010, 11:34:52 am »
Sorry to up this one, is Papaga8tor still available ?
« Reply #13 on: January 06, 2010, 12:15:39 pm »
hi  le_pou,  :)
yes! Papaga8or stiil avaliable, "but the Forum has with error" for attachmente file!!
i send the tool for a alternative link, please download your copy in:
http://www.4shared.com/file/189852711/600a38f1/papaga8or_V01.html
att.
le_pou
« Reply #14 on: January 06, 2010, 12:42:35 pm »
Thank you merci neirao, will give you feed back, thanks again !
