Author Topic: Exporting in roblox format (.mesh)  (Read 24315 times)
ANormalUsername1
« on: September 21, 2008, 03:50:47 pm »
I need help with exporting in .mesh format.
I need help with exporting, because when I export it, the points in the mesh don't show up, or it doesn't export it fully.
I got this script strieght from the roblox wiki:
  Description: Add this to your Anim8or scripts directory and start Anim8or. The script MUST have the ".a8s" extension and be in the Anim8or Scripts folder. Make sure that "Preload Scripts" is set to ON (this is NECCESSARY). This script has been tested for 0.95 and 0.97 preview.
#plugin("object", "export", "Roblox Mesh", ".mesh");
#file($output, "text");
#return($result);
file $output;
int $result;
object $obj;
shape $shape, $shapes[1], $childShapes[1];
tridata $data;
material $mat;
int $numFaces;
point3 $point, $normal, $color;
point2 $uv;
int $i;
int $j;
int $index, $mIndex;
int $count;
float $gCol;
string $nm;
string $newName;
float4x4 $tMatrix;
$nm = $output.GetRoot();
$obj = project.curObject;
$output.print("version 1.00\n");
$obj.GetShapes($childShapes);
$shapes.size = 0;
while($childShapes.size > 0)
    $shapes.push($childShapes.pop());
while($shapes.size > 0)
       $shape = $shapes.pop();
       $shape = $shape.ConvertToMesh();
   $data = $shape.GetTriangleData();
          $numFaces = $data.GetNumTriangles();
   $tMatrix = $shape.GetGlobalTransform();
   $output.print("%d\n",$numFaces);
   for $i = 0 to $numFaces - 1 do {
      for $j = 0 to 2 step 1 do {
         $index = $data.GetIndex(($i*3)+$j);
                       $point = $data.GetPoint($index);
                      $point = $tMatrix.Project($point);
                       $normal = $data.GetNormal($index);
                       $uv = $data.GetTexCoord($index);
         $output.print("[%.6g, %.6g, %.6g]", $point.x, $point.y, $point.z);
         $output.print("[%.5f, %.5f, %.5f]", $normal.x, $normal.y, $normal.z);
         $output.print("[%.5f, %.5f, 0]", $uv.x, $uv.y);
$result = 1;
I would be grateful If someone could help.
ANormalUsername1
Re: Exporting in roblox format (.mesh)
« Reply #1 on: September 21, 2008, 03:56:59 pm »
It would say
version 1.00
144
with 144 being the amount of points in the mesh.
ANormalUsername1
« Reply #2 on: October 05, 2008, 06:26:31 pm »
Anybody???
NickE
« Reply #3 on: October 05, 2008, 07:00:40 pm »
Are you using the latest version?  I had no problem with the script in version 0.97d.  Version 0.97b had a bug that broke export scripts.
I am not familiar with roblox, but the script did write a text file with a .mesh extension containing data in the format specified in the script.
ANormalUsername1
« Reply #4 on: October 11, 2008, 02:49:49 pm »
~MOD EDIT: link removed - Floyd86~ I didn't know that. I guess I need to update.
« Last Edit: March 03, 2009, 12:41:41 pm by floyd86 »
Tay Zonday
  • Check me out on Youtube! Youtube.com/TayZonday
« Reply #5 on: October 13, 2008, 01:32:32 pm »
It works for me...
Allow me to introduce myself
My name is Tay
It's T-A-Y, T-A-Y to the Z.
-Credits to Joe-
jabermony
« Reply #6 on: March 03, 2009, 11:41:05 am »
i get that problem i made a new head and only the sphere showed up
